eLayerList 3.4-Excluding layers
679
08-30-2013 09:40 AM
EricVenden
Robert,
I am using the 3.4 eLayerList.  I have added numerous layers to be "excluded" in the config file for the widget.  I am finding that if I remove some layers using the excludelayer tag, the layer does not show up on a print (using the default Print widget).  I have attached an image showing one service listing.  If I remove any of the address layers/sublayers (0-4), these layers do not show up on the exported PDF (or image) - even though they are displayed in the application.
Is this expected behavior?
Thanks for your time.
Eric V
Gurnee, IL
RobertScheitlin__GISP
Eric,
   To be honest I have never tested that. I am not sure if this is the expected behavior in the OTB LayerList widget but if it is then that is why the eLayerList is the same.
