Attachment Relate Info Widget for 3.4 (quick question)
448
08-30-2013 11:26 AM
TimHayes
I am using this widget (InfoTemplate) in 3.0. It works great.
Is there a version of this widget for 3.4?
If not, what do you recommend for showing hyperlinked photos and specific fields when a point in a point feature class is clicked on inside the Flex Map Viewer?
NOTE: I am not using the AppBuilder, I am coding in XML.
RobertScheitlin__GISP
Tim,
   That widget was retired as the OTB popups in the viewer handle almost everything that that widget did. Hyperlinked photos is a basic feature of popups. See Doc here:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Pop_up_configuration_files/01m3...
Tim,
