Dynamic Legend
1768
6
11-02-2010 03:56 AM
PrestigeMakanga
Is there anyone with a dynamic legend widget for the new viewer?
Regards
Prestige
RobertScheitlin__GISP
Prestige,
   You need to look at the code gallery.
http://help.arcgis.com/en/webapps/flexviewer/gallery.html
RayGreen
Robert,
Is there a version that will work with Flex 2.1 and ArcGIS 9.3.1?  I assume that this one will not work with that combination?
Ray
Ray,
   Nope, there is not one of FlexViewer 2.1 and Server 9.3.x.
RayGreen
Reason #4523 to keep bothering people for the upgrade.  Thanks Robert!
Ray
NadeemShaukat
Prestige,
Robert,
I installed the source in my project. My web service in on ArcGIS Server 10. I declared my web service in the config.xml file within <operationlayers> block as the following.
<layer label="MyLayers" type="feature" visible="false"
             url="http://66.60.222.111/ArcGIS/rest/services/MyGIS/MapServer"/>
My DynamicLegengWidget.xm looks like this.
<?xml version="1.0" ?>
<excludeLayers>
  <excludeLayers mapservice="MyLayers"> </excludeLayer>
</excludeLayers>
<excludeGraphicLayers>true</excludeGraphicLayers>
</configuration>
When I run the program, I get Error #2035.
Where I am wron. Can you please help?
nshaukat
nshaukat,
You have a syntax error in your xml.
<excludeLayers>
</excludeLayers>
The beginning and closing element name have to identical and that particular element is suppose to be excludeLayer not excludeLayers.
