Dynamic layers disappear on large monitor
799
06-07-2012 11:05 AM
ThomasDyer
I'm running an application of the Viewer with dynamic point layers overlaid. We have begun to deploy 27" monitors to some of our users. I received a call that the map would open with the ESRI Streets base map and the legend populated with the point symbols, but no symbols were visible on the map. After a day of frustration, checking the application and the data sources, I discovered if you didn't maximize the screen the features would display. But, as soon as the browser was maximized they would disappear. Any ideas on a cause or solution to this strange problem would be appreciated.
RobertScheitlin__GISP
Thomas,
   I believe you are running into a max image output size issue. Here is a thread with details and resolution
http://forums.arcgis.com/threads/21732-ArcGISDynamicMapServiceLayer-Will-not-display?p=73478&viewful...
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Thomas,
ThomasDyer
I like a thousand before me say, "Thank you, Robert." Has ESRI considered hiring you just to answer forum questions? You are the best tech support the company has.
