Draw Widget with Pan tool
1080
04-16-2013 08:24 AM
HelioHiroshi
I`m using drawWidget (flexviewer 2.1), I added some mouse events to the graphics made by the tool, but its seems to ignore the pan tool when i`m trying to move inside a graphic. The pan tool only works if I remove all the mouse event listeners from the graphic. I saw the latest version of this widget and it doesn`t have this issue, is there some way to change just this aspect?
omega_cancer
After you are done with edittool you need to reset it to make the map work normally.When you are one with it call:
setMapAction(null,null,null,null);
Hope that it will solve your issue.
Thanks
