Display 9.3 Service and use SimpleInfoWidget
1052
10-13-2010 01:54 PM
MichaelVanhook
I have setup the FlexViewer and began to adjust code. I cannot migrate from 9.3 at this time and the help site says that most functionality works with 9.3 services but I can't even get it to work with ESRI's 9.3 services.
            <layer label="Census" type="dynamic" visible="true" alpha="1" icon=""
                   visiblelayers="3"
                   info="widgets/InfoTemplates/SimpleInfoWinWidget.swf"
                   infoconfig="widgets/InfoTemplates/IWT_Census.xml"
                   url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer" />
Here is the widget config
<?xml version="1.0" ?>
<configuration>
    <fields>NAME,CNTY_FIPS</fields>
    <titlefield>NAME</titlefield>
    <datefields></datefields> <!-- field in milliseconds -->
    <zoomscale>150000</zoomscale>
</configuration>
Services can be viewed as operational layers.
Any help using 9.3 services until I can migrate?
AlexJones
Try changing the type from dynamic to feature and setting the url to a specific layer.
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/0
Make sure it is in the list of operational layers.
            <layer label="Census" type="feature" visible="true"
                   url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/0" />
MichaelVanhook
Sorry Alex, I am trying to get a 9.3 dynamic service to work. Changing the value to "feature" (v10 layer type) did not work. Also the layer is selected by using the "visiblelayers" property. Counties are layer level 3.
                   visiblelayers="3"
Thanks -
Mike
AlexJones
Mark
On this help page under concepts -> Configure the viewer -> layer tag
http://help.arcgis.com/en/webapps/flexviewer/help/index.html
# tiled: a cached ArcGIS Map Service (9.3 or later)
# dynamic: a non-cached ArcGIS Map Service (9.3 or later)
# feature: a single layer in an ArcGIS Map Service or Feature Service (9.3 or later)
All of these just need a 9.3 or later server.
The config-all.xml has examples of operational layers using the simpleInfoWinWidget. If you want to use dynamic that will work for display and keep the symbology from the MXD. Type feature (using a 9.3 service) will use default symbology in the viewer. See this thread.
http://forums.arcgis.com/threads/14685-Layer-does-not-display-as-a-quot-feature-quot-type-in-ArcGIS-...
When using type feature it needs to hit a single map service as I said. ...mapserver/1, ...mapserver/2, ...mapserver/3, etc. So depending on if you want the SimpleInfoWinWidget or not will influence how you hit the service. Again the config-all has really good samples of what you can do. I hope this helps a bit.
