Disable link if field is null in Popup
4055
06-05-2013 08:42 AM
MattPohl
Has anyone been able to disable links in popups if the field is null? This can be found in Robert's eSearch widget and is very nice feature eliminating the confusion users have who are not familiar with the process when they try to click on a link and nothing happens. Possible enhancement to a future release?? Any help is appreciated.
Matt
RhettZufelt
MVP Notable Contributor
If using source code, that is fairly simple in the popuprendererskin.
see here:  http://forums.arcgis.com/threads/67874-Popup-3.0-hide-field-if-value-null?highlight=popup+hide+null
R_
RhettZufelt
R_
MattPohl
Rzufelt-
Thanks for your replay. I was looking for an answered Thread on this but didn't see the one you referenced. I'll give it a shot. Thanks again.
Matt
RhettZufelt
Doesn't actualy "disable" the link, the thread shows how to not display that field in the popup window if the field is null so there will be no link to click on.
However, the this is the same place you would modify code if you wanted blank links to still show, but say something else.
Something similar to:
if !(formattedAttributes[fieldInfo.fieldName]){
   formattedAttributes[fieldInfo.fieldName] = " No Link Available"
R_
