Spatial search in Eserach
980
06-04-2013 08:41 AM
ZhujingXia
Robert,
In the spatial search of the enhanced search 3.0, is that possible to keep the first result highted even after you create buffer and search the entites? Right now after you searched the entities, the high lights will be the new search entities not the first search result before you create buffer. I'd like to keep them both high lighted.
Also, after you click the searched entities, the map will zoom to the level based on the entities layer, may i still keep the zoom level base on the set up base on result layer used to create buffer before, or the the buffer graphic layer.
Zhujing
RobertScheitlin__GISP
Zhujing,
   None of what you are wanting is possible without you changing the code for your specific use case.
ZhujingXia
Robert,
Is that a lot of places need to change? Could you point out which functions need to modify?
zhujing
RhettZufelt
MVP Notable Contributor
I don't do spatial searches, so can't really test, but I see in version 3.0.14, he added the "add to current selection" option.
Does the spatial search with buffer not support this, or can they be "added" to the initial selection?
R_
