Data extract tool - ArcGIS Server 10.2
3449
09-27-2013 01:37 AM
GavinWepener
The shapefile and file geodatabse formats works 100% when using the Data extract widget in ArcGIS Viewer for Flex 3.4. However when I try to extract the same feature in any of the default CAD formats, the output zip file is just empty. No errors, just empty.
Any ideas as to what I am doing wrong?
Regards,
Gavin
MarkSteele2
I had the exact issue this week.  After a few hours on the phone with ESRI support, they discovered that it is a known issue with 10.2 that will be fixed in SP1.  Until then browse to your scripts folder on both your desktop and server, rename the ExtractData.py and replace it with the file attached.  Rerun/publish the models and you should be in good shape.
Below are the locations for the scripts directories for desktop and server.
Desktop (Win7):  C:\Program Files (x86)\ArcGIS\Desktop10.2\ArcToolbox\Scripts
Server (Win2008):  C:\Program Files\ArcGIS\Server\ArcToolbox\Scripts
Good Luck!
MarkSteele2
Good Luck!
GavinWepener
Thanks Mark!
Your solution work 100% first time around.
DanielSmith
Good Luck!
worked for me too... many MANY MANY THANKS
DanielSmith
So out of curiosity i ran a Diff on the version supplied here and the one that was replaced.
there was only one change to the clip or the clip_convert functions but wan in the except statement. the changes seem to be in the zipUpFolder function and the makeOutputPath function and mainly deal with strings and unicode chars....
EzequiasRodrigues_da_Rocha
It works for misplaced characters also? like:
Explora�??º�??úo.shp
where expected
Exploração.shp (in Portuguese)
This kind of problem is a matter of server configuration or the widget configuration?
Regards
Ezequias Rocha
