Linking Images Stored on a Seperate Server
1338
06-12-2013 04:25 AM
KevinLaughlin
Greetings!
I will preface this by stating that I've only been using the ArcGIS Viewer for Flex for the past few weeks, so bear with me on this.
I have a fairly standard application with a few of the canned widgets up an running on our local network, nothing special.  For the past several days I've been investigating/attempting ways to link scanned documents (That are saved as .TIFF images) to a point feature class I have (In my mind, something similar to hyperlinking in ArcMap) but to no avail.  I've tried doing so through the "Configure Pop-ups" in the Maps tab, as well at trying to get creative with the Identify Widget that's available through ArcGIS Resources.  I can't really get either of them to work.
My first question is this: is it possible to (not really knowing the proper term) "Hyperlink" documents from a separate server.  The documents reside at location such as this: P:/Engineer GIS/Projects/Section Corner... (The path is much longer, but you should be able to get the picture) while my Flex Application resides on a separate server: E:/Survey2.  The linkes are saved via a field called "Hyperlink" in the point attribute table.  If I do so through the Pop-up Configuration, I just get an empty box where the image should be and if I do so through the Identify Widget, I get a link that doesn't go anywhere.  Also, I am using FlexViewer 3.2 with ArcGIS Server 10.1.
So, I guess my question is: can the Flex Application link to documents on different server? Or, would I have to place them within the E:/Survey2 folder and have to rework the link field?
If further clarification is needed I can provide it, at this point I'm not sure what it would be, so I haven't uploaded any screenshots or provided any code.  Any guidance regarding this is greatly appreciated!
Kevin Laughlin
GIS Specialist
Wood County Engineers Office
AnthonyGiles
Honored Contributor
Kevin,
You cannot hyperlink to images/documents using a local path name (I.e. e:/......) it must be done through a URL. What you would need to do is set up a virtual directory in IIS that points to the location of we're the files are sat. That way you will be able to access the file by a correct URL. It is this URL that would need to go into your link field,
Hope this makes sense
Regards
Anthony
AnthonyGiles
Honored Contributor
Kevin,
Regards
Anthony
KevinLaughlin
That was kind of the direction that I was heading, I just needed the answer.  Thanks Anthony!
SteveGoates1
How about a UNC path instead of a URL?  (i.e. \\192.168.1.8\apn\etc)
Works on other web based applications that i have (asset management system), but not in flex viewers.
The link URL comes out as ttp://servername/flexviewers/Appname/\\192.168.1.8\apn\etc  so that obviously doesn't work.
Is there a way to not use the flex viewer's virtual directory and just use the UNC, the link opening locally?
OlegLukyanov
BTW
What is the best method to create hyperink to image\document?
I think it is better to write path to field with drag and drop document in ArcMap and Viewer for Flex but I have not seen such add-ins.
Oleg
