customized arcgis sample for flex SearchWidget cannot get the expect field value arraylist
2892
11-25-2014 12:01 AM
WuYang
I am new to flex. Now I am trying to customize the SearchWidget from arcgis-samples-flex-3.6-src. What I want to do is:
(1) use the drawing tools provide in the sample on a layer from the layer list.
(2) get a specified field values of all the features in the drawing area (of the selected layer) in a arraylist.
Now I can access the layer, but I failed to get the expected arraylist (the fieldValues in the following code).
private function queryFeaturesGraphical(geom:Geometry):void
  hideInfoWindow();
  var searchLayer:Object = cboLayerGraphical.selectedItem;
  queryLayer = searchLayer.layer;
  retrieveFieldValue(searchLayer);
private function retrieveFieldValue(obj:Object):void
  CursorManager.removeBusyCursor();
  var fieldset:FeatureSet = obj as FeatureSet;
  fieldValues = uniqueArray(fieldset.features);
private function uniqueArray(arr:Array) : Array
  var unique : Array = new Array();
  var contains : Boolean;
  for( var i:Number = 0; i<arr.length; i++ )
  contains = false;
  unique.push(arr);
  return unique;
What I use is arcgis flex api 3.6 and flash builder 4.6.
Would anybody please advice me what is wrong with my code? thanks.
RobertScheitlin__GISP
Leaf,
   Is there parts of your queryFeaturesGraphical function that you have omitted for some reason?
I don't search anywhere in that function that an actual query occurs on the queryLayer...
Leaf,
WuYang
Thanks Robert,
I didn't post part of the queryFeaturesGraphical because the program is stuck when performing onFieldValuesRereivalsuccess at the line of
mFldValues = uniqueArray(fset.features);
I cannot figure out the reason.
I will check the code for the query part.
Best Regards
WuYang
Hello Robert,
Currently I am trying to confirm whether I can get the features selected first, in this case I follow the SearchWidget (just modified the xml to catering to my map service).
Since it is a different question, I posted it as a new thread:
https://community.esri.com//thread/117907
Appreciate if you can have a look, thank you.
WuYang
Hi Robert,
I have already got the issue fixed, thanks for the kind help.
