flex sample searchwidget get RPC Fault "failed to execute query"
3535
12-02-2014 12:07 AM
WuYang
Hi all,
I am now following the SearchWidget from arcgis-samples-flex-3.6-src to my web service and just change th xml file to my own service.
When I ran the application, it find the layer and no error message BUT the RPC Fault "failed to execute query" error as follows
The modified xml file is:
<?xml version="1.0" ?>
<configuration label="Spatial Search">
    <layers>
        <layer>
            <name>ROADLINE</name>
            <url>http://localhost:6080/arcgis/rest/services/GeoTagging_for_web/MapServer/0</url>
            <expression>DrainName like '[value]'</expression>
            <textsearchlabel>Search road by name</textsearchlabel>
            <titlefield>PD_NAME</titlefield>
            <linkfield></linkfield>
            <fields all="false">
                <field name="OBJECTID"/>
                <field name="RoadName" alias="Road Name"/>
            </fields>
        </layer>
        <layer>
            <name>Segment</name>
            <url>http://localhost:6080/arcgis/rest/services/GeoTagging_for_web/MapServer/1</url>
            <expression>Segment_ID = '[value]'</expression>
            <textsearchlabel>Search by Segment ID</textsearchlabel>
            <titlefield>Segment_ID</titlefield>
                <field name="Segment_ID" alias="Segment ID"/>
            </fields>
        </layer>
    </layers>
    <zoomscale>10000</zoomscale>
</configuration>
Any hint on what may cause the problem? thanks!
RobertScheitlin__GISP
Wu Yang,
  The issue I see in your configuration is that you have:
And this field likely does not exist in your layer.
Next you have:
But DrainName field is not listed in your fields:
            </fields>
Another big thing to know is that Flex is a CaSe sensitive language so you have to have the EXACT CaSe of your fields in the config.
Wu Yang,
Next you have:
            </fields>
WuYang
Yes Robert,
I have corrected the configuration, it works. Thanks a lot!
UPDATE: a stange thing is all the results displayed at the same place cause the results looks messy.
