CSV Mapping Widget
792
02-21-2011 09:45 AM
MESHALALMASHAN
Is there anyway in using a dojo widget just like (http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/ags_mapwithtab...)
as a custom widget in the ArcGIS Viewer for Flex? If not, any ArcGIS Viewer for Flex alternative widget doing the same functionality, i.e., projecting coordinates saved in a csv-file/db on maps?
BjornSvensson
Esri Alum
No, you cannot use Javascript widgets inside the Flex Viewer (nor vice versa).
However, take a look at this "Map Your Point Data" application which sounds like it has the functionality you are asking for (in a Flex Viewer widget):
http://www.arcgis.com/home/item.html?id=fabdd320b0724ab2957c7af297008d89
MESHALALMASHAN
Yes it does! Thanks.
