Creating  Multipoint and adding graphic through ActionScript
3982
9
10-20-2012 10:27 PM
shabbirsiddiqui2
I am trying to create MultiPoint through ActionScript and want to add graphic on the map, but it throwing error,
TypeError: Error #1034: Type Coercion failed: cannot convert []@1022e3a1 to com.esri.ags.geometry.MapPoint.
at com.esri.ags.symbols::SimpleMarkerSymbol/draw()
at com.esri.ags::Graphic/drawWithSymbol()
at com.esri.ags::Graphic/commitProperties()
at mx.core::UIComponent/validateProperties()
at mx.managers::LayoutManager/validateProperties()
at mx.managers::LayoutManager/doPhasedInstantiation()
at mx.managers::LayoutManager/doPhasedInstantiationCallback()
can any one please suggest me what is the problem in this code to add graphic on the layer .
Here is my Code.
var myMulPoint:Multipoint = new Multipoint(
    new MapPoint(1447100, 7477200),
  ]],  new SpatialReference(102100));
var myGraphicMulPoint:Graphic = new Graphic();
myGraphicMulPoint.geometry = myMulPoint;
myGraphicMulPoint.symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_TRIANGLE, 22, 0x009933);
myGraphicsLayer.add(myGraphicMulPoint);
RobertScheitlin__GISP
Shabbir,
   Glad you got it working. Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
Shabbir,
   You should give each one of your geometries a spatial reference always. This code works:
                var sr:SpatialReference = new SpatialReference(102100);
                        new MapPoint(1447100, 7477200, sr),
                        new MapPoint(1447400, 7477600, sr),
                    ]], sr);
shabbirsiddiqui2
Shabbir,
                    ]], sr);
Dear Robert ,
After giving each geometries a spatial reference as you said,
same error is throwing as it was before, there is no any change in the error.
Regard,
Shabbir Ahmad Siddiqui
Shabbir,
  You have something else wrong in your code then as I tested this and it works fine. Here is the whole test app I did.
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:mx="library://ns.adobe.com/flex/mx"
               xmlns:esri="http://www.esri.com/2008/ags"
               xmlns:s="library://ns.adobe.com/flex/spark">
    <fx:Script>
        <![CDATA[
            import com.esri.ags.Graphic;
            import com.esri.ags.geometry.MapPoint;
            import com.esri.ags.geometry.Multipoint;
            import com.esri.ags.SpatialReference;
            import com.esri.ags.symbols.SimpleMarkerSymbol;
            private function init(evt:Event):void
                    ]], sr);
    </fx:Script>
    <esri:Map id="myMap">
        <esri:ArcGISTiledMapServiceLayer url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer" load="init(event)"/>
        <esri:GraphicsLayer id="myGraphicsLayer" />
    </esri:Map>
</s:Application>
shabbirsiddiqui2
Shabbir,
    <fx:Script>
        <![CDATA[
                    ]], sr);
    </fx:Script>
    </esri:Map>
</s:Application>
Dear Robert,
  I exicuited the test application ,even in this test application same error is throwing,
I am using the flexviewer 2.5
What may be the issue, although through MXML i can create the MultiPoint without error .
Regards,
Shabbir,
   Hmm... When you say
I executed the test application ,even in this test application same error is throwing,
The test add I made is a Flex API stand alone application nothing to do with Flex Viewer and was built and tested using the Flex 2.5 API so I know for a fact that it works without error. I am really unsure what issue you are having.
When you say you are trying to use your code in Flexviewer 2.5, are you adding it to a widget or what? Maybe you should share all of the code that you are using in your viewer (i.e the widget or where ever you are attempting to add the code to).
shabbirsiddiqui2
Shabbir,
   Hmm... When you say
Dear Robert,
I am using the the stand alone application, which i have attached , Please check what is the issue with it .
Regards,
Shabbir,
   I am not sure why, but the code I posted wrapped the points array in another array for some reason and this caused the issue.
Bad code:
                    ]], sr);
Working code:
var myMulPoint:Multipoint = new Multipoint([ new MapPoint(1447100, 7477200, sr), new MapPoint(1447400, 7477600, sr)], sr);
shabbirsiddiqui2
Shabbir,
Bad code:
                    ]], sr);
Working code:
Dear Robert,
  Thanks Robert, its work now.
Regards,
Shabbir,
