Attachment_Inspector in Widget
1510
10-23-2012 11:51 AM
AuraRamos_Lora
Could someone help me change this code for Widget, I attach files to my map and control it with a widget and I try to make changing the code but I was very disappointed, I still have much to learn: (
http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Attachment_Inspector/01nq0000000s00...
Saludos cordiales
BjornSvensson
Esri Alum
Hi Aura,
What version of the Flex Viewer (and Flex API) are you using?  The screenshot makes me think it's an older version (Sample Flex Viewer).
What is it that you are trying to do?  If it's just using the attachment inspector to add and remove attachments, then Flex Viewer (through the Edit Widget) has supported this since version 2.1 which was released in 2010.
BjornSvensson
Esri Alum
Hi Aura,
AuraRamos_Lora
I appreciate the clarification did not know you could with edit widget, I'm working with version 3, has little I am using this platform. And I struggled to accommodate my widgets, my forte is the ArcGIS desktop, but with this forum I learned a lot and helped me a lot with this new project.
My site is already insured with Token, and I modified the Sigin, and everything is fine but I want some widgets will be activated depending on the role assigned to the user, that's possible? Any ideas to get started ..
I appreciate your attention.
[ATTACH=CONFIG]18676[/ATTACH]
