Create Email with Hyperlink to share map extent
7964
21
10-12-2011 06:23 AM
JustinConner
I've been trying to use the Pass URL parameters from the Flex API samples to pass a hyperlink of the map to an email message. I'd like to offer my users an easier way to share a map extent that doesn't require using the Bookmark Widget. There is great example of this on the Javascript gallery http://localgovtemplates2.esri.com/ParkFinder/default.htm. I really wish the esri development teams would release these the same tools across all the APIs.
RobertScheitlin__GISP
Justin,
   Have you seen the documentation on the Viewer URL Params?
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Viewer_URL_parameters/01m3000000290000...
JustinConner
I get that part (I think).
At the moment when I click on my button a new browser opens ( I know not an email but baby steps right?) and the URL generated seems correct but the map doesn't respond to those coordinates but rather stays at 0,0.
I'm also getting an error because it wants a configuration xml file along with it.
Justin,
   Time to attach your button click code then.
JustinConner
Justin,
I'm a complete novice at this but I'm trying to learn. I'll have to look back at the FIAW course to see what you mean.
Justin,
   Sorry I meant that I want you to attach your button click code that you are using for me to look at.
JustinConner
Justin,
Be gentle i'm still learning. 🙂
<?xml version="1.0" encoding="utf-8"?>
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
       xmlns:s="library://ns.adobe.com/flex/spark"
       xmlns:mx="library://ns.adobe.com/flex/mx"
       xmlns:viewer="com.esri.viewer.*">
 <fx:Script>
   <![CDATA[
    import com.esri.ags.geometry.MapPoint;
    import com.esri.ags.utils.WebMercatorUtil;
    import mx.controls.Alert;
    private function createPermalink():void
     var currentCenter:MapPoint = WebMercatorUtil.webMercatorToGeographic(map.extent.center) as MapPoint;
     navigateToURL(new URLRequest(
      "index.html?center="
      + myDegreeFormatter.format(currentCenter.y)
      + myDegreeFormatter.format(currentCenter.x)
      + "&scale="
      + Math.round(map.scale)), "_blank");
    private function getURLParameters():Object
     var result:URLVariables = new URLVariables();
     try
      if (ExternalInterface.available)
       // Use JavaScript to get the search string from the current browser location.
       // Use substring() to remove leading '?'.
       // See http://livedocs.adobe.com/flex/3/langref/flash/external/ExternalInterface.html
       var search:String = ExternalInterface.call("location.search.substring", 1);
       if (search && search.length > 0)
        result.decode(search);
     catch (error:Error)
      Alert.show(error.toString());
     return result;
    private function setMapLocation():void
     var params:Object = getURLParameters();
     if (params["ll"])
      var latlong:Array = String(params.ll).split(",");
      if (latlong.length == 2)
       map.centerAt(WebMercatorUtil.geographicToWebMercator(new MapPoint(latlong[1], latlong[0])) as MapPoint);
     if (params["scale"])
      map.scale = params.scale;
  </fx:Script>
  <fx:Declarations>
   <mx:NumberFormatter id="myDegreeFormatter"
        precision="6"
        useThousandsSeparator="true"/>
  </fx:Declarations>
 <viewer:WidgetTemplate id="passURL"  widgetTitle="Pass URL" width="200" height="100">
  <s:HGroup id="groupURL">
   <s:Button click="createPermalink()"
       fontSize="14"
       fontWeight="bold"
       label="Create a hyperlink"/>
  </s:HGroup>
 </viewer:WidgetTemplate>
</viewer:BaseWidget>
JustinConner
I got it to work albeit to a new browser window and not an email message.
 <fx:Script>
   <![CDATA[
     var currentCenter:MapPoint = (map.extent.center) as MapPoint;
      + "&scale="
     try
     catch (error:Error)
     return result;
     if (params["ll"])
       map.centerAt(new MapPoint(latlong[1], latlong[0]));
  </fx:Script>
  <fx:Declarations>
        precision="0"
        useThousandsSeparator="false"/>
  </fx:Declarations>
       fontSize="14"
       fontWeight="bold"
  </s:HGroup>
Justin,
  Try this:
var request:URLRequest = new URLRequest("mailto:[email protected]?subject=Map Link&body=index.html?center=" + myDegreeFormatter.format(currentCenter.x) + "," + myDegreeFormatter.format(currentCenter.y) + "&scale=" + Math.round(map.scale))
navigateToURL(request,"_blank");
JustinConner
Almost there!
The browser window still opens which I dont need and the map scale is not being included in the email link. It is showing at the end of the URL in the browser window.
Example of link from email message:
http://gis.co.wood.wi.us/Flex24/index.html?center=-10020714.32477927,5534890.079940923
Example from browser window:
mailto:[email protected]?subject=Map Link&body=http://gis.co.wood.wi.us/Flex24/index.html?center=-10020714.32477927,5534890.079940923&scale=9028
