Could not fetch basemap data: Security error accessing url
4676
13
03-27-2013 10:50 AM
DanielSmith
Looks like this is effecting the Esri Flex samples as well as my apps. any word on the issue?
http://resources.arcgis.com/en/help/flex-viewer/live/index.html
[ATTACH=CONFIG]23009[/ATTACH]
once you clear all the errors the basemaps do render...
DanielSmith
Am I the only one seeing this?
ScottZwick
I'm having the same issue. Even when I clear them all the map does not render. Have you had any luck?
JasonEwert1
Nope. I'm getting the same thing with version 3. I noticed it at 1:00 today, March 27th. The viewer does fade in as I clear the errors, and the base maps function as normal.
BjornSvensson
Esri Alum
It's a problem related to default basemap group from ArcGIS online.  It should be fixed very soon.
DanielSmith
Thank you Bjorn!
My Apps are all good as of 1:30 PST
ErikMartin
Thanks, Bjorn -- glad I came across this thread before too much longer...
ScottZwick
I unchecked the "Add Portal for ArcGIS Basemaps"  box and now it works.
KurtLebo
Have the same issue starting arount 10:00 AM today.
BjornSvensson
Esri Alum
This has now been fixed on arcgis.com.
You might have to clear your cache to see it fixed.
