Coordinate Menu Widget - New !
14001
95
02-17-2011 07:51 PM
Drew
Hello Everyone,
I created a new widget that you might find useful.
Tucked away in the map context menu are three XY operations
   1.     Copy XY
   2.     Project XY (configurable)
   3.     Go To XY
ReadMe.txt included
Hope you find it useful!
Click Here to demo and download the Coordinate Menu Widget
Drew
Drew
hi can you teach me how to add RSO Kertau projection into this widget.....
Below are the WKID's that are might be what you are looking for.
WKID         Name
4751          GCS_Kertau_RSO
24500  Kertau_Singapore_Grid
24547  Kertau_UTM_Zone_47N
24548  Kertau_UTM_Zone_48N
24571  Kertau_RSO_Malaya_Chains
Add the one that your looking for under the CoordinateMenuWidget.xml file under the <CoordinateSystems> tag
Drew
idapodrug
Is this widget available for Flex Viewer 3.2? If not then will the 3.1 version work with it?
Thanks!
Drew
Thanks!
I have not tried it with 3.2 yet, but feel free to see if it works and post your results.
My initial guess is that it will work.
Drew
EmmaAlterton1
Has anyone got this working with Flexviewer 3.3?
I've upgraded and Coordinate Menu 3.1 won't work with the new Flexviewer.
Will a new version of the widget be available?
Emma
RhettZufelt
MVP Frequent Contributor
I copied the 3.1 version directly from my widgets folder in FlashBuilder and pasted into the widgets folder in my 3.3 version.
Seems to be working just fine.
R_
EmmaAlterton1
Hello
I'm only using the compiled widget for the flexbuilder.
Although I updated the widget in Flexbuilder it seems it didn't fully update, so I did as suggested and simply copied and pasted the compiled widget folder to the flexviwers/widget folder.
The tool now works although when I right click and the context menu appears my mouse pointer disappears.
It comes back if you escape out of the context menu or click away from the menu (if you click away you have to guess that the mouse is off the menu somewhere as it isn't visible).
Any ideas?
Emma
Drew
I have updated the coed on the project site.
There were no changes, i just recompiled and added into the .zip as 3.3
Enjoy.
http://www.arcgis.com/home/item.html?id=edd4a2b7c722493a8b08f53eaa131e1e
EmmaAlterton1
Hello
Thanks for the compiled code.
For anyone who is interested I found the issues I have with mouse pointer visibility only occurred with existing applications that I upgraded through the flex builder app. If I create a new application and add the Coordinate menu in the tool works great.
I found that a number of the custom widgets have a few issues/odd behaviour when used with an upgraded existing application but in a new application they work fine. As I only have a couple of applications I'm going to recreate them from scratch as this seems to fix all the issues I have.
Emma
SpatialNinja
Hi, will you be able to recompile to Flex 3.5 ? Thanks!:)
Solutions Engineer | Spatial Ninja  | GIS ️ | Telecommunications
GeorgeHaskett
Thanks for the great widget!
Any updates on the 3.5 version?
