Controlling events in EDIT Widget
1041
06-25-2012 10:18 AM
SaugatJoshi
I am trying to save the length of drawn graphic in the feature attribute. I have got the length of line feature. However, When I try to add it in editsStartingHandler I never have the calculated length available. I know this is because of the Async nature of flex, but I wanted to know where could I add the appropriate event listener function.
In populateEditor(), we have
oplList.layer.removeEventListener(FeatureLayerEvent.SELECTION_COMPLETE, featureLayer_selectionComplete);
oplList.layer..addEventListener(FeatureLayerEvent.EDITS_STARTING, editsStartingHandler);
//oplList.layer..addEventListener(GeometryServiceEvent.LENGTHS_COMPLETE, editsStartingHandler); This returns geometry event which I cannot use in editsStartingHandler().
oplList.layer.addEventListener(FeatureLayerEvent.SELECTION_COMPLETE, featureLayer_selectionComplete, false, 1);
private function editsStartingHandler(event:FeatureLayerEvent):void
    //////////////////////////////////////////NEW ADDITION FOR ADDING LENGTH ON MAP /////////////////////////////////////////////////
    var geom:Geometry = new Geometry();
    var spatialref:Number=102003;
    var outSR:SpatialReference = new SpatialReference(spatialref);
    geom=event.adds[0].geometry;
    geometryService.project([ geom ], outSR);
    //var tok1:AsyncToken =geometryService.project([ geom ], outSR, new AsyncResponder(projectCompleteHandler, proj_fault, tok1));
    //tok.addResponder(new AsyncResponder(projectCompleteHandler, proj_fault, tok));
    var polyline:Polyline = geom as Polyline;
    //ViewerContainer.addEventListener("lengthCalc", sendServer);
    Alert.show("DONE!!!!");
    Alert.show(lengthFea.toString());
    trace("Before event.add");
     if (event.adds)
     event.adds[0].attributes['transformation_transaction_id'] = ttid;
     event.adds[0].attributes['user_id'] = userIDNum;
     event.adds[0].attributes['user_name'] = userName;
     event.adds[0].attributes['active'] = _activeNo;
     event.adds[0].attributes['phase'] = "ACTIVE";
                                        event.adds[0].attributes['len'] = lengthFea;
     if (event.adds)
     event.adds[0].attributes['_id'] = id;
        private function projectCompleteHandler(event:GeometryServiceEvent):void
    var geom:Geometry = (event.result as Array)[0];
    var lengthsParameters:LengthsParameters = new LengthsParameters();
    var pLine:Polyline = Polyline(geom);
    lengthsParameters.geodesic = true;
    lengthsParameters.polylines = [ pLine ];
    //var tok2:AsyncToken =geometryService.lengths(lengthsParameters, new AsyncResponder(lengthsCompleteHandler, proj_fault, tok2));
    geometryService.lengths(lengthsParameters);
   //private function lengthsCompleteHandler(result:Object, token:AsyncToken):void
   private function lengthsCompleteHandler(event:GeometryServiceEvent):void
    var leng = (event.result as Array)[0]*3.28;
    var data:Object=
      length:leng
    ViewerContainer.dispatchEvent( new AppEvent("lengthCalc",data) );
//private function sendServer(event:AppEvent):void
   //var lengthFea:String=event.data.length.toString();
   //Alert.show(lengthFea.toString());
I am trying to find the Drawend event or the place where I can add the event listener before events.add[] and add a events.add[] in that listener function . I have used event listeners and asyc token responder...however I cannot catch the drawend event in this widget. Some help would be greatly appreciated. Thanks.
