An issue with Attachment Relate Info Window Widget version 3.0 for FlexViewer 3.0
2523
06-19-2012 07:54 AM
by Anonymous User
Not applicable
Original User: 3alaeddine
Hi all,
I have an issue with the information display of my info window widget. When I click on a set of features and I click on show related permit button (snapshot 1), I get a new window showing a table containing the information associated to the first selected feature. But when I close this window (snapshot 2) and I select the second feature (snapshot 3), the display of the feature information completely changes (snapshot 3). This problem just happens the first time I click on a set of features to show the info window widget.
I am wondering what the origin of this problem could be.
Thank you very much for your help.
RobertScheitlin__GISP
Alaeddine,
   What you are seeing the first time is the my AttachmentRelateInfoWin widget and the last snapshot you are showing is the standard ESRI popup window because you have that layer defined with a esri popup as well. You should really use one or the other.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
by Anonymous User
Not applicable
Original User: achen70
Alaeddine,
Hi, Robert
Would you mind share the source code of Attachment Relate Info Window Widget version 2.4 with me please?
Amy
Amy,
   Sure here is what I have for 2.4
Don't forget to click the top arrow (promote).
by Anonymous User
Not applicable
Amy,
Wow, you are so nice, i got it in less than half hour. Thanks
Would you please take a look this thread ----http://forums.arcgis.com/threads/60661-Help-with-esearch-Widget-version-2.4
Amy
