Config questions for the Viewer
535
08-19-2013 08:39 AM
ChadHall
My boss is reviewing one of our viewers and had a couple comments.  I'm sure there's a way to do it with the uncompiled version (which we don't use) but I was curious if it was possible with the compiled version.  Here are the comments:
1) Legend widget has too much space between the layer and symbol and then between layers.  Can this be compressed?
2) Under "More Data", can the configuration be modified to allow the parent box of a group to auto-check the child boxes?  Right now, it looks like you have to check the child boxes and then go check the parent box which is a little tedious if you want to turn on the whole group at once.
3) Also, I'm trying to find the place where to add the cursor coordinates onto the map (lat/lon, DMS, etc) but I haven't found it yet.
Any help would be appreciated!
Thanks
Chad
ChadHall
Found the coordinate widget part...right under my nose!
