Communication between Widget and TOC Component
2026
6
07-21-2011 09:16 PM
NitinBele
How can I fetchSharedData() From TocItemRender.as ?
Any suggestions ?
Thanks ,
Lu.
RobertScheitlin__GISP
Lu,
   In the past I have just traversed up the parent list until I got to the widget. Probably not the best way but it worked.
NitinBele
Thanks Robert !
Could you pls help me with some sample code for traversing to Widget from the component ?
Lu
Lu,
   Maybe you should tell me your workflow and or objective, the more I think about this the more complicated it is getting.
NitinBele
Lu,
Thanks Robert for your time !.
My workflow - i have a widget "W1" and I want to enable a specific Layer in the TOC (visibility on and off ) only after I get an input from "W1" say hit a "ok" button.
My workaround:
calling addsharedData() in "W1" and passing a boolean value in arraycollection.
fetching the boolean value in TocItemRender.as to on\off the specific Layer.
But i did not get fetchshareddata() funtion here.
please help me out if you could suggest me a better logic or a way to get to fetchSharedData()
TocItemRender.as .
Thanks Robert again for youe ultimate support.
Lu
Lu,
   So the only thing the fetchSharedData function is doing is dispatching an appEvent:
ViewerContainer.dispatchEvent(new AppEvent(AppEvent.DATA_FETCH_ALL));
Which in turn dispatches this event:
ViewerContainer.dispatchEvent(new AppEvent(AppEvent.DATA_SENT, dataTable));
in the DataManager.as.
So from W1 dispatch this event:
var data:Object =
                key: key,
                collection: arrayCollection
        ViewerContainer.dispatchEvent(new AppEvent(AppEvent.DATA_PUBLISH, data));
and in the toc add this listener:
ViewerContainer.addEventListener(AppEvent.DATA_PUBLISH, sharedDataUpdated);
Then just a function that handles the event:
private function sharedDataUpdated(event:AppEvent):void
                var data:Object = event.data;
                if (data.key == "your Key Name")
                    //todo
NitinBele
Thanks Robert ! It worked really great.
I only need to change
from
To
ViewerContainer.addEventListener(AppEvent.DATA_NEW_PUBLISHED, sharedDataUpdated);
Lu.
