Retaining symbology of map services and feature layers
2937
8
12-31-2010 08:35 AM
DonBarker
My question is indirectly related to the Flex viewer:
When I show this map service in the Flex viewer
http://129.2.24.243/Semental2/rest/services/CRH_L1-L2/MapServer
the scale-dependent and layer-dependent symbology is retained in the viewer.
But when I use separate feature layers (because I can use the InfoPopup window only with feature layers) like this one
http://129.2.24.243/Semental2/rest/services/CRH_L1-L2/MapServer/2
the symbols are big, ugly dots.
Any way to control the feature layer symbology in the viewer?
Don
RobertScheitlin__GISP
Don,
   If you are using a layer type of Feature and you are not using ArcGIS Server 10 than you will not be able to retain the symbology that is specified in ArcMap. In FlexViewer 2.2 there is not an easy way to fix this unless you put some custom code in the MapManager.mxml. In FlexViewer 2.3 this will be a different story I'm told. The best solution is to be up to date on ArcGIS Server (i.e. ArcGIS Server 10 SP 1) there is just to many advances and advantages of 10 to not go ahead and update.
MehulChoksey
Feature Drawing rendering info is returned by AGS server starting with version 10. Flex api takes advantage of this drawing info and also it honours scale dependency.
e.g. see Drawing Info section at:
http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/0
You have 9.31. So creating your own renderer/symbol would be way to go.
deleted-user-NnRwwd8ols89
Hey guys, i'm a bit confused about feature layer symbology. I'm using Flex API 2.2, and server 10, and can return the symbology as defined in the msd's from the server no problems.
i have just upgraded to server 10, previously i have used feature layers a limited amount with server 9.3.1 and defined each layers symbology individually in the mapmanager.mxml
i thought however that one of the benefits of feature layers is client side graphics, so my question is should i use the symbology from my msd, or redefine everything as the feature layer symbology? i'm about to start a big project with c.60 layers, so i want to get it right from the start and make it as efficient as possible!
thanks
Ben
Ben,
   Now that you upgraded to Server 10 you should be getting symbology for the individual feature layers so when you were using 9.3.1 and specified http://myArcGisServer/ArcGIS/Rest/Services/MyService/2 you would have gotten ugly default symbology but now with 10, http://myArcGisServer/ArcGIS/Rest/Services/MyService/2 should return the exact symbology see in ArcMap as long as the symbology is supported. Are you not seeing this?
Hi Rob, yes this is what i get, the nice symbology for each layer when called individually. i just wanted to make sure that this is best practice!
thanks for all your help and advice
MichaelMorgan
I'm trying to use a public service that doesn't support ArcGIS 10 symbology, http://ags.pdc.org/rest/services/GHIN/PDC_Active_Hazards/MapServer/10. Nice little hurricane symbols in their Google Earth preview, big ugly dots in my Viewer. Is there an easy way to symbolize this data client-side in the Viewer? I'd like to symbolize polygon features client-side as well, see http://ags.pdc.org/rest/services/GHIN/PDC_Active_Hazards/MapServer/22.
Mike Morgan
MichaelMorgan
Yes, that did it. Thank you, Robert.
