Code error-between 2.4 and 2.5 viewer
883
12-07-2011 05:06 AM
EricVenden
I have tweaked the Identify widget a bit a couple versions ago (2.3) and have upgraded these changes along the way (2.3.1 & 2.4)  With 2.5, I'm getting 2 errors and I'm hoping someone may possibly be able to assist me.  This code works fine in 2.4, but in 2.5 I get 2 errors in FB:  1) Expecting identifier before rightparen  2) expecting rightbrace before if
Looks like all the braces and parens are in the proper spot.
Here's the code:
//Start Code
      if (lyrList.links != undefined) {
       var linksList:XMLList = configXML..links.link;
       for (var x:Number = 0; x < linksList.length(); x++)
        lyrLinks.push(
          title: String(linksList.@title),
          icon: String(linksList.@icon),
          url: String(linksList)
//End added code
Eric
RobertScheitlin__GISP
Eric,
  The error is not in this code so you must have introduced the error in this code blocks parent.
Eric,
   Care to share the rest of the code for multiple links?
