Changing the expand behavior on "Table of Contents Widget for FlexViewer 2.x"
1156
01-25-2012 11:05 AM
by Anonymous User
Not applicable
Original User: bcgis
I'm trying modify Robert's code to only expand only the "top layer"? I have this functionality coded in my old 1.3 Flexviewer that I figured out, so I assume this is possible but after spending a couple of days on it I can't seem to figure it out.
The problem is with using "extended=true" is that it expands lengthy layers such as "soils' and some layers don't expand at all. This is what I get by default in the first screenshot. What I would like to see is in the second screenshot.
Bo
by Anonymous User
Not applicable
Original User: rscheitlin
Bo,
   Now looking closer you might get your desired result by using:
    <tocsettings>         <expanded>true</expanded>         <collapselegends>true</collapselegends>     </tocsettings>
in the TOCWidget.xml
by Anonymous User
Not applicable
Bo,
BoCastillo
That did the trick. I looked at the XML I don't know many times and outright missed that tag. :confused:
by Anonymous User
Not applicable
Bo,
   Glad you got it working. Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
