changing extent dynamically
1301
05-19-2011 11:48 AM
SaugatJoshi
Hi all,
I have 3 buttons in viewer.I have extents for each of these from the database..
Button 1- zooms to football field
button 2- zooms to university building, and
button 3- zooms to nearby police station.
Where can I change the code to achieve something like this in the same map? The initial extent will be the extent from button 1. What about other two extents.
Thank you.
SaugatJoshi
Guys,I think I got it. Below is the code....I have my three extents in a combobox instead of Buttons. Below is the snippet
//changeView is the event listener for combo box's change property
private function changeView(event:Event):void
    var viewExtent:Extent=new Extent(Number(bboxArray[0]), Number(bboxArray[1]), Number(bboxArray[2]), Number(bboxArray[3]), null);
    selectedExtent = viewExtent;
    map.extent=selectedExtent;
    //mx.controls.Alert.show(selectedView);
bboxArray has xmin,ymin,xmax and ymax values respectively which I get from the database.Please don't forget to write if statements depending on you case.
Thanks.
MohdShah
Hello all
I try same code but
got this error
1046: Type was not found or was not a compile-time constant: Extent.
RobertScheitlin__GISP
Mohd,
   That is a really BASIC programming concept... You need to import the extent type.
import com.esri.ags.geometry.Extent;
