Change content of Splash widget
1766
7
06-08-2011 07:04 AM
AnthonyPagan
I'm new to the FlexViewer I'm trying to change the content of the splash widet this is what I have:
<widget preload="open"
config="widgets/Splash/SplashWidget.xml"
url="widgets/Splash/SplashWidget.swf"/>
then this is my splashwidget config file:
<configuration>
<width>375</width>
<height>375</height>
<content>
<![CDATA[<p align='center'>
<img src='assets/images/globe.png' width='140' height='140' />
</p>
<p>
<font size="16"><b>Welcome to Huber Heights GIS.</b></font>
</p>
<p>
This application was developed with ArcGIS Viewer for Flex.
</p>
<p>
More information at links below:
</p>
<textformat blockindent="20">
<p>
* Built with <a href="http://help.arcgis.com/en/webapps/flexviewer/" target='_blank'><font color="#FFFFFF"><b>ArcGIS Viewer for Flex</b></font></a>
<br>
* Based on <a href="http://help.arcgis.com/en/webapi/flex/" target='_blank'><font color="#FFFFFF"><b>ArcGIS API for Flex</b></font></a>
</p>
</textformat>
<br>
<p>
<a href="http://www.esri.com/legal/pdfs/mla_e204_e300/english.pdf" target='_blank'><font color="#FFFFFF">(c) Copyright 2011 Esri</font></a>. All rights reserved.
</p>
</content>
<btnlabel>Click to continue</btnlabel>
</configuration>
What am I doing wrong?
RobertScheitlin__GISP
Anthony,
    Do you have a splashpage element setup in your main config.xml? if not then you need to be editing the HeaderControllerWidget.xml content element.
AnthonyPagan
Robert,
I do not have a splashpage element setup in my config.xml I will edit the HeaderControllerWidget.xml. Thanks for the help. Also how can I set up a splashpage element setup in my config.xml. Thanks
AnthonyPagan
Robert,
I edited the HeaderControllerWidget.xml and I still got the original content that comes with it here is the code:
<configuration>
    <about>
       <label>About</label>
       <visible>true</visible>
       <width>375</width>
       <content>
        <![CDATA[<p align='center'><img src='assets/images/globe.png' width='140' height='140' /></p>
        <br><p>This application is developed with ArcGIS Viewer for Flex 2.</p>
        <br>More information at links below:
        <textformat indent="25"><p><br><a href="http://help.arcgis.com/en/webapps/flexviewer/" target='_blank'><font color='#FFFF00'>ArcGIS Viewer for Flex</font></a>
        <br><a href="http://help.arcgis.com/en/webapi/flex/" target='_blank'><font color='#FFFF00'>ArcGIS API for Flex</font></a>
        <br><a href="http://www.esri.com" target='_blank'><font color='#FFFF00'>Esri</font></a></p></textformat>
        </content>
        <btnlabel>OK</btnlabel>
    </about>
</configuration>
AnthonyPagan
Robert,
Thanks
AnthonyPagan
Ok I must be really bad at this I changed everything that the help docs say and I still get the original message here is my code:
<splashpage label="Splash" config="widgets/Splash/SplashWidget.xml" url="widgets/Splash/SplashWidget.swf"/>
splash config file:
<configuration>
    <width>375</width>
    <content>
        </p>
        <p>
        </p>
        <p>
        </p>
        <p>
        </p>
            <p>
                <br>
            </p>
        </textformat>
        <br>
        <p>
        </p>
    </content>
</configuration>
I have looked thru the resource center read everything I was pointed to don't know what else to do.
AnthonyPagan
Thanks everybody got it working!!
