BUG 3.4 EditWidget (Editor/AttributeInspector) Undo
1573
07-18-2013 06:57 AM
NickG
I found this bug trying to set up my own edit widget.  Decided to double check in the default viewer to make sure I wasn't doing something wrong.  Got the same result.  Apologies in advance, this should probably be in the api forum.
1. Open Edit Widget
2. Check "San Francisco 3-1-1 Incidents"
3. Click feature on map to open inspector
4. Edit any attribute
5. Click Ok
6. Click Undo and receive the following error:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at com.esri.ags.components::AttributeInspector/validate()
at com.esri.ags.components::AttributeInspector/set activeFeatureIndex$()
at com.esri.ags.components::AttributeInspector/set activeFeatureIndex()
at com.esri.ags.components::AttributeInspector/refresh()
at com.esri.ags.components.supportClasses::EditAttributesOperation/undoattributeInspector_editsCompleteHandler()
at mx.rpc::AsyncResponder/result()
at com.esri.ags.tasks::FeatureLayerTask/handleApplyEdits()
at Function/http://adobe.com/AS3/2006/builtin::call()
at com.esri.ags.tasks::BaseTask/handleResultEvent()
at mx.rpc::AsyncToken/http://www.adobe.com/2006/flex/mx/internal::applyResult()
at mx.rpc.events::ResultEvent/http://www.adobe.com/2006/flex/mx/internal::callTokenResponders()
at HTTPOperation/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent()
at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::resultHandler()
at mx.rpc::Responder/result()
at mx.rpc::AsyncRequest/acknowledge()
at DirectHTTPMessageResponder/completeHandler()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at flash.net::URLLoader/onComplete()
MehulChoksey
Thanks for reporting. This is an API bug and has been logged.
MichaelVolz
Esteemed Contributor
Is this bug restricted to the 3.4 API?  Or does it also occur in earlier APIs?
I'm just asking so I know which API to build my editing application in, until this bug is fixed.
NickG
Works in 3.3.  Seems that with 3.4 its an issue with the new validation functionality.  Unfortunately the validation is what I need.
BjornSvensson
Esri Alum
Version 3.5 was released today and includes the fix for this issue:
* Runtime error when performing an "undo" during editing. Bug was specific to version 3.4.
