Attribute Table displays twice???
1417
01-30-2014 09:18 AM
VenusScott
Please tell me I'm not the only one who is experiencing this!! In the Layout tab I've activated the Attribute Table option and configured it to have the initial state "Collapsed". I did not include any layers to show because I only want the "Search" results done after a search to display. When I go to the preview tab, the Attribute Table is duplicated?!! (image attached). This is version 3.5 and I'm totally stumped by this? Anyone else ever experience this? How did you fix it?
[ATTACH=CONFIG]30987[/ATTACH]
RobertScheitlin__GISP
Venus,
   What you nned to do is look at the main config.xml file in a text editor program and see if you have the attribute table widget listed twice.
i.e. C:\inetpub\wwwroot\flexviewers\yourappsname\config.xml
do you have something like this?
    <widgetcontainer paneltype="bottom" initialstate="collapsed" size="250">             <widget label="Attribute Table"                 config="widgets/AttributeTable/AttributeTableWidget.xml"                 url="widgets/AttributeTable/AttributeTableWidget.swf"/>             <widget label="Attribute Table"                 config="widgets/AttributeTable/AttributeTableWidget.xml"                 url="widgets/AttributeTable/AttributeTableWidget.swf"/>     </widgetcontainer>
Venus,
VenusScott
BINGO!!!
Thanks Robert! Once I delete the duplicate entry, life is good once again!
Venus,
   Glad to help. Did you mean to mark your inital question as the answer?
