Flex Attribute Widget - Open to "Select by Attribute" instead of "Select features by"
1281
01-29-2014 11:37 AM
GregSnelling
I'm using v3.6 and would like the attribute widget to default to the "Search by Attributes" panel instead of "Select Features by".  I guess I need to modify the config file, but not sure.  Anyone done this already?
Thx,
Greg
RobertScheitlin__GISP
Greg,
   OK then all you need is the <initialview>text</initialview> tag added to your SearchWidget.xml. You can find this in the docs here:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Search_widget_tags/01m300000023...
Greg,
   There is no Attribute Widget. Can you make sure you are using the proper widget name or provide a link to the widget download.
GregSnelling
Sorry, I meant the "Search Widget".   I'm using the default "Search Widget" in the ArcGIS Viewer for Flex 3.6 Application builder.
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#//01m300000038000000
Greg
Greg,
GregSnelling
Wow, it was right there in front of my face the whole time...  Thanks for your help Rob!
