Add Excel Widget For Flex Viewer 3.1
1336
01-28-2013 01:20 AM
AnthonyGiles
Honored Contributor
All,
Updated version of the Add Excel widget is now available to work with 3.1:
http://www.arcgis.com/home/item.html?id=b8d2f6a9063e44669eddfdd2d32244e8
Regards
Anthony
Tags (3)
GeorgeHaskett
Hello,
I downloaded the new version for Flex 3.1 and seem to be having problems with it.
All my data is lumped together in the Gulf of Guinea...
The coordinates appear to be correct as they work in other applications.
I formated the spreadsheet Latitude and Longitude columns to number with 5 digits past the decimal.
Any suggestions?
I am using ArcGIS 10.1 Desktop and Server software with Viewer for Flex 3.1.
Haskett
AnthonyGiles
Honored Contributor
George,
Do the coordinates in your excel spreadsheet share the same projection as your application, and do you have the x and y values the correct way round?
Regards
Anthony
RyanColeman
Hi i'm having an issue getting the widget to work in Flex Viewer 3.1
1172: Definition com.esri.ags.geod:Ellipsoid could not be found.    AddExcel.mxml    /FlexViewer3.1/src/widgets/AddExcel    line 22    Flex Problem
1172: Definition com.esri.ags.geod.geom:MoreUtils could not be found.    AddExcel.mxml    /FlexViewer3.1/src/widgets/AddExcel    line 23    Flex Problem
I copied as3xls into the com folder and added the library to the library path. I have agslib 3.1 installed and i'm using Flex 4.6.0. I added AddExcel.mxml to the flex modules. I'm guessing it has something to do with the agslib but I'm not sure what i'm missing here, any ideas?
AnthonyGiles
Honored Contributor
Ryan,
Have you got the libraries from the original widget found here:
http://www.arcgis.com/home/item.html?id=56d4d2ed5d474eb4b8e29973d2376652
Regards
Anthony
