Enhanced Search issue
964
02-22-2013 05:24 AM
by Anonymous User
Not applicable
Original User: edsnyder2
Here is the error message I'm getting: [RPC Fault faultString="invalid or missing input parameters. "faultCode="400" fault Detail=""]
Here are my expressions for the search.
            <expressions>
             <expression alias="Parcel #" textsearchlabel="Search Parcel #:" isvaluerequired="false">
              <values>
               <value prompt="No Dashes or Points needed!" isvaluerequired="false">State_ID like '%[value]%'</value>
       </values>
             </expression>
             <expression alias="Deeded Owner" textsearchlabel="Search Owner:" isvaluerequired="false">
              <values>
               <value promt="Example: John Smith" isvaluerequired="false">Deeded_Own like '%[value]%'</value>
              </values>
             </expression>
             <expression alias="Parcel Address" textsearchlabel="Search Parcel Address" isvaluerequired="false">
              <values>
               <value prompt="Example: 222 W Monroe St" isvaluerequired="false">Street like '%[value]%'</value>
              </values>
             </expression>
             <expression alias="Property Class" textseachlabel="Search by Property Class" isvaluerequired="false">
              <values>
               <value prompt="Example: 510" isvaluerequired="false">Prop_Class like '%[value]%'</value>
              </values>
             </expression>
             <expression alias="Neigborhood Code" textsearchlabel="Search by Neighborhood Code" isvaluerequired="false">
              <values>
               <value prompt="Example: 902501" isvaluerequired="false">Neighborho like '%[value]%'</value>
              </values>
             </expression>
             <expression alias="Section, Township, Range" textsearchlabel="Search by Section, Township, and Range" isvaluerequired="false">
              <values>
               <value prompt="Section" isvaluerequired="false">Section like '%[value]%'</value>
               <value prompt="Township" isvaluerequired="false">Township like '%[value]%'</value>
               <value prompt="Range" isvaluerequired="false">Range like '%[value]%'</value>
              </values>
             </expression>
            </expressions>
Thanks in advance
AnthonyGiles
Honored Contributor
Ethan,
Where you have multiple values you need an operator attribute (AND or OR), eg:
<value prompt="Township" isvaluerequired="false" operator="AND">Township like '%[value]%'</value>
<value prompt="Range" isvaluerequired="false" operator="AND">>Range like '%[value]%'</value>
also if any of your fields are numeric you need to use fieldname = [value] not fieldname like '%[value]%'
Regards
Anthony
