November Velocity Update --
327
11-05-2025 09:43 AM
JeffSilberberg
Well last night two of my customer Velocity ionstances were updated --
"version": "6.3.0",
"licenseLevel": "advanced",
"licenseEndDate": 1793516399000,
"clusterRegion": "US",
"cluster": "advanced",
"subscription": "............................",
"computeUnits": 0,     <------ Does Not Look correct.
"storageUnits": 0  <------ Does not look correct
I have multiple instances of the Feeds and Analytics not restarting, even after deleting and resubscribing the token .. In many cases, I do not have log data other than the Failed Status.  In some cases, after the Token refresh, the RTA will not start. "Save and Fix Validation Errors Before Starting,"  if I click on the Start Icon. But, if I open the RTA in Edit mode, then just return to the List of RTAs and try again, it does start.
I have seen absolutely no documentation or release notes yet.  So I am not even sure what I am looking for.
Note, I have not opened tickets, as historically, Support has been useless!
Just Venting !!!!!!!!! An looking to see what others are experiencing --
JeffSilberberg
Still having multiple issues from 6.3.0 upgrade.
Strongly recommend you use Swagger and document the state of Velocity objects weekly, if not more often, if you have many more items than you can start at one time. AKA: various versions of the same analytic.
Also, on a positive note, there is now a compatible node to the geoEvent choice function as well as a new Merge that supports up to 10 inputs.
https://doc.arcgis.com/en/velocity/analyze/route-by-expressions.htm
JeffSilberberg
The Development Team got involved, and both customers are running again..
