What's New in ArcGIS Velocity (November 2025)
227
11-06-2025 10:31 AM
DMolnar
The November 2025 update of ArcGIS Velocity introduces expanded support for new data providers and new real-time analytics for streamlined workflows. Highlights in the latest release include:
Feeds
Support for four new data provider feeds has been added:
  • Access real-time firefighting telemetry by connecting to the TracPlus Cloud using the TracPlus feed.
  • Connect to DTN‘s real-time and forecast feature layer services to receive hyperlocal and industry-specific weather data with the DTN Weather feed type.
  • Receive real-time location data for vehicles and assets to monitor their status and movement using the Motive AVL feed.
  • Integrating the TAK Client (Beta) feed into Velocity allows users to receive events from a TAK server.
Analytic tools
  • Combine two to ten input pipelines with matching feature geometry types into a single schema using the Multi-Merge tool.
  • Evaluate records using ArcGIS Arcade Expressions and route each record to multiple destinations based on defined conditions using the Route by Expression tool.
Read the blog for more details on the new and enhanced features.
1 Comment
JeffSilberberg
Already tried the new Merge, and it significantly simplified the RTA I used to test against.  The Route by Expression is not opening the Arcade expression window in the RTA I was going to try it in, but it made be my issue as I had a lot of things open and running.
Contributors
