General HTTP Poller Basic Authentication Question
1446
05-13-2024 10:20 AM
Teresa_Blader
I get intermittent authentication errors on my HTTP Poller feed connected to an API - requesting every 5 minutes. Currently asking my IT to explore any issues on their end - it happens 3-5x per day and resumes after the error mostly in this last two weeks I think. Only downside is I seem to be missing some events. The basic authentication is a username and password that IT gave me for this API call.
Is there anything on the ArcGIS Velocity side that I need to be doing regularly to prevent this (like does doing a reset refresh token relate?) - or is this kind of a thing likely just on the API authentication side?
Anyone know of anything I should be recommending IT check? Or is this normal? Is this a sign I'm requesting too frequently? I plan put in a support ticket officially, once I hear back from IT.
Teresa Blader
Olmsted County GIS
GIS Analyst - GIS Solutions
JeffSilberberg
@Teresa_Blader
The Error Message looks similar to an issue I have that Support is working on.  I would open a ticket on this with support as the "Feed Started at .....encountered a run time error." implies a Velocity error not an issue with the API you are targeting.  You might also change the Log level to Debug when viewing and see if there is any more detail.
JeffEismanGIS
Hi @Teresa_Blader were you able to submit a ticket? Can you message me directly with the Ticket and we can look into your issue a bit further on our end.    Thanks
Teresa_Blader
Thanks! I did. Not really getting anywhere. I will message directly!
Teresa Blader
Olmsted County GIS
