Well, I never got any responses. But I did find a way to do it.
In ArcGIS Pro, if I added a Vector tile basemap from ArcGIS Online, and tried to use the Share menu, Web Layer / Publish as a Web Layer, And the tile option. . It told me the layer's data source was not supported.
But, if I used the Geoprocessing tool. "Create Map Tile Package" it would work. Then all I had to do was go to Portal and Add Item from Computer.
One other small item. If I used tried to set the extent in the geoprocessing tool, it still tried to export the entire world. BUT, if I set the Extent in the Map Option, I got it to just tile the area I was interested in.
Hope that helps someone else.
