Is there a way to replace base map layers while maintaining the original map ID. We currently have a group of Esri basemaps that our users use when creating maps and apps. Recently, a new freeway connecting two interstates has opened that is not depicte
1149
08-24-2020 09:37 AM
RobertFairchild
Basically what I am trying to do is replace the topographic basemap we have saved and use throughout our organization with an updated vector topographic basemap while maintaining the original map ID.  This way all current applications using the original topographic map will now have the updated vector topographic basemap.
ORIGINAL
VECTOR TOPOGRAPHIC
Tags (1)
DanPatterson
MVP Esteemed Contributor
Do you have an organizational basemap setup?
Have you saved the original and copied over the new one to the old name?
... sort of retired...
