Please fix this glitch that has existed for months
2703
11-17-2021 07:37 AM
BrianE1
This small gap appears on all vector basemaps from Esri when the boundaries are taken off. This is the Hudson River between NYC and Jersey
Also, what is with the two colors of the water?
Esri, please fix. Its annoying that I need to photoshop this out everytime I export the map out.
Thanks
John-Foster
we will look into this and get back to you. thanks for reporting it.
--jf
jcarlson
In the Vector Tile Style Editor, you can actually see that the "two colors" is due to the Land/Not Ice layer showing trough the water layer, either because of transparency of layer blending. Not all basemap styles include this layer, and as with any layer in the vector style editor, you can remove/restyle it as needed.
- Josh Carlson
Kendall County GIS
Andy-Green
The boundary gap should be resolved in our December release (~16th of the month).  Thanks for the comments.
In addition to Esri Community, we have basemap, geocoding and imagery feedback services where users can add comments on the map and get items fixed:  https://www.arcgis.com/home/group.html?id=e796c4f5b27b431a804184fc51d10b40#overview
GreerJarrett
This glitch still exists. The only current solution is to deactivate the land layer in ArcGIS VTSE, to download the custom basemap, and then to load a secondary basemap from ArcGIS Pro under the custom one, which "hides" the gaps. Not ideal.
