Validate Network Topology web tools
1444
02-14-2023 04:36 AM
GIS_Solutions
Is there a way to run the Validate Network Topology tool as web tools? I published this tool on the portal with the "share as a web tools" method. But I am getting an error while running the tool.
Thanks.
MikeMillerGIS
Esri Frequent Contributor
I do not think you can publish this tool.  The tool would need the URL of the Utility Network and the version to validate.  I am not sure how to pass this info to a published GP tool.  You need to call the validate rest end point.  I believe the ExB team is working on a widget to do this.  I am not sure when it will be available.
GIS_Solutions
Hi @MikeMillerGIS
Yes i actually had some trouble publishing the tool. But when I add the utility source from the map, I can publish the service successfully.
There is a situation as I mentioned in the screenshot. The service is running successfully, but the tool errors while running.
As far as I understand, EXB widget is under development, is it currently not possible to Validate topology outside of ArcGIS Pro? 
