Utility network Trace widget functionality not working
2670
10-25-2022 12:49 AM
by Anonymous User
Not applicable
Hi all,
I currently have an electric utility network service published and then consumed inside a map with a few named trace configurations enabled published to online and in instant apps using the utility network trace widget but I am unable to see the output selection attributes Is there any dependency on field case sensitivity? For OBJECTID and Graphic color selection also not working.
Can somebody explain to me what is the exact issue
Attaching screenshots for reference
AlixVezina
Hi @Anonymous User , there is currently a bug with selections and case sensitivity of the objectid field name. We have fixed this and it will be resolved in the widget for the upcoming ArcGIS Online and ArcGIS API for JavaScript 4.25 updates in November. The fix will show up in your online Instant App as well.
OliviaZ_Meowth
Hi @AlixVezina ,
Could you provide the bug info/number, thanks
AlixVezina
@OliviaZ_Meowth , there is currently no bug number for this OBJECTID case sensitivity issue (which will affect displaying the list of selected features result). Often we will discover issues internally and still fix these, but a customer may not have filed a BUG report for it.
Please test it out on Friday this week, or next week, and let me know if you are still seeing the issue.
OliviaZ_Meowth
Thank you very much @AlixVezina , I will update with you once I test on this Friday.
AlixVezina
@Anonymous User Looping back on this, for the Graphic selection color to be available, please make sure to enable Aggregated Geometry as a Result Type when you run Add Trace Configuration in ArcGIS Pro.
