Utility network priviledges
2649
04-22-2020 04:18 AM
FilipKuzman
Hi everybody,
I am trying to grant privileges in my Enterprise Geodatabase for the Utility Network dataset to the other users in SQL Server. Dataset is branch versioned. I have added users through the GP tool Create Database User in ArcGIS Pro and then assigned dbcreator role to them in SQL Manager. However, if I try to add privileges to any of them on my UN dataset(as UN owner) I got 'Unsupported operation for utility network datasets.' Even just for select option. Does the UN support multi-users on its dataset? Or am I missing something?
Thank you
AnthonyRyanEQL
Filip,
I'm working on a Utility Network project and we have created a read only user within SQL Server 2016 to access the schema that the utility network resides in.
This was development by our implementation partner
SQL to execute
USE [<db_name>]
CREATE USER [<RO username>] FOR LOGIN [<RO username>] WITH DEFAULT_SCHEMA=[<UN schema name>]
GRANT SELECT ON SCHEMA :: [<UN schema name>] TO [<RO username>]
Good luck
FilipKuzman
That worked!
Thank you Anthony.
PierreloupDucroix
MVP Regular Contributor
Hello, does anyone have more information on this?
Is this normal behavior in Utility Network? If so, why?
I've reproduced the problem with ArcGIS Pro 11.5 and PostgreSQL.
I was able to grant read access to a UN dataset via SQL, but not through ArcGIS Pro's privilege management.
CEO of MAGIS
RobertKrisher
Users should not be directly connecting to the geodatabase to access utility network data, they should be using services.
PierreloupDucroix
Thanks, Robert. We primarily use the SDE connection file to export data from the default version via administrative toolboxes or scheduled tasks.
I know feature services and the Portal offer better privilege management, but in some cases, direct access to the geodatabase offers better performance than using a feature service, and I don't want to share the data owner's connection file. That's why a read-only user would be helpful.
CEO of MAGIS
