Utility Network - Edit Existing Attributes
713
08-24-2022 05:36 AM
Ron_Richard
Hello.  I am new to using the Communications network and noticed the fields present in each of the Feature Templates are NOT editable.  The current fields do not work for our company/needs and I'd like to modify them to be more in line to the info we are looking to store on the network.  Any help/tips would be appreciated.
JohnAlsup
The best way to remove fields is to use a configuration to remove them.  Then, we take care of removing them as network attributes, etc.
https://solutions.arcgis.com/utilities/help/utility-network-automation/asset-package-reference/d-con...
Next, when adding fields, consider using data types of numeric instead of strings.  Strings cannot be used in network attribute.
John Alsup
[email protected]
