User interface is stuck when creating features (UN)
610
01-19-2026 02:28 AM
mykola
I am testing the UN editing in Arcgis pro 3.5 and every time I select a feature from the feature template and place it on a map, the user interface freezes. All tools are greyed out but I still can navigate between tabs. Then I have to restart the arcgis pro. The feature that caused the UI to stuck is present on the map after the restart. I though maybe it has something to do with the attribute rules but another coworker has no issues with editing. Could not find anything helpful online to help me resolve this issue.
mykola
After several tries I came to the conclusion that I need to select a correct version before editing. I though it was initially due to some attributes rules but other coworkers could edit the same data. Anyway, I guess so far the correct version is the solution. I hope there is nothing more that causes this issue.
RobertKrisher
If you create a new feature template and create a feature, do you see the same behavior? If you haven't already, log a case with support.
mykola
