Update Subnetworks completing successfully but subnetworks remain dirty
2961
04-19-2022 11:35 AM
JonathanDaweEsriUK
Hi Utility Network Questions,
I am encountering odd behaviour with the "update subnetworks" task where, even though the process is running successfully, all of the subnetworks (in the subnetline and subnetwork table) are still showing isDirty: true.
Set up:
  • I have deployed the ArcGIS Solution Sewer Data Management (V1) in an ArcGIS Enterprise 10.9.1 environment.
  • No changes have been made to default since publishing the Utility Network Service and there are no dirty areas in the network that require validation.
  • I originally ran update subnetworks via the geoprocessing tool in ArcGIS Pro, and now have been running it via REST. In the server logs I am not seeing errors and notice that assets are correctly populated with their subnetwork names.
I'm a bit confused at whether I am missing something that could be preventing the subnetworks for showing as no longer dirty?
PaulLeBlanc1
I believe Manage IsDirty is False in the Sewer model, so that behavior is expected.
See https://pro.arcgis.com/en/pro-app/latest/help/data/utility-network/set-or-modify-the-subnetwork-defi... step 10
PaulLeBlanc1
JonathanDaweEsriUK
Hi Paul, thanks that makes sense, I don’t think I fully grasped the impact of that setting.
Out of interest, what is the use case for having Manage isDirty set to false like this?
John_Medema
Is this functionality available in Pro 2.9.x?
John_Medema
Found it in the help archive!
PaulLeBlanc1
  1. During data migration / cleanup there isn't typically a need to track subnetwork state. There is a cost associated with this, so disable it to speed up the process.
  2. Subnetworks are required to define direction (eg for upstream/downstream traces). If there isn't a need to export subnetworks, then similar to #1, there isn't a need to track state.
