Update subnetwork not updating supported subnetwork name on a Electric Assembly feature
1144
11
01-18-2026 01:15 PM
YulissaCamacho
Hi. Our team find a problem with a electric utility network that we are using, when we de-energized some part of a subnet, everything downstream change the subnetwork name to "Unknown" but no the transformer bank that we set as a Electric Assembly. After running update subnetwork the supported subnetwork field keep the name of the subnet, even though the transformer electric device and the pole that the bank has associated with don't have subnetwork name.
We have the  Include Containers in the trace configuration options check with the Include Structure Network Containers and Include Domain Network Containers in the tier's subnetwork definition.
Any ideas?
RobertKrisher
Following up on this. It turns out it was a bug.
RobertKrisher
Are you doing this in a named version or default? What are the edit mode configurations for the subnetwork definition for the subnetwork you're updating?
YulissaCamacho
This happend both in default and named version
gis_KIWI4
MVP Regular Contributor
Are all the contents of the assembly correctly updated to Unknown after disconnecting? Just wondering if there is some content that might stopping it from updating.
YulissaCamacho
Yes, the transformer devices that are content and the pole that is attached are updated to Unknown
RobertKrisher
Please log an issue with support. If your subnetworks are configured to populate the subnetworkname field on assemblies, then it should also set it to unknown when their content is no longer supported.
RobertKrisher
JordanScupien
Robert,
Is there a workaround for this bug?  Im experiencing this in Gas and water isolation traces
RobertKrisher
The bug only occurs on update subnetwork, so I'm not sure it applies to isolation traces. Can you explain?
JordanScupien
I have 2 different issues Im working on my apologies. The 1st is I am exporting subnetwork controllers from a oracle database to a SQL database.  After importing the controllers all the water subnetworks come in perfectly---but once I use the update the subnetworks tool the pressure subnetworks disappear and come in as unknown.  The controllers and linework are the same in both databases.
