UNTools for ArcGIS Pro 3.5.x
336
09-04-2025 05:59 AM
SanchezNuñez
Good afternoon,
I uploaded ArcGIS Pro to 3.5.x  but I cannot find the UNTools in the package Manager. Is the UNTools available for version 3.5.x?
Thanks
RobertKrisher
I just created a new clone using ArcGIS Pro 3.5.0. At first, the tools aren't visible:
Then I refreshed the metadata for my packages.
And then they appeared.
CodyPatterson
MVP Regular Contributor
Hey @SanchezNuñez
It appears that it is available: https://www.esri.com/arcgis-blog/?post_type=blog&p=2789102&preview=true
https://www.esri.com/arcgis-blog/products/utility-network/announcements/whats-new-utility-network-20...
I can find it here on my own Pro:
I would check to be sure you're in the Add Packages section, or check the Installed/Updates for potential updates!
Cody
RobertKrisher
Make sure you are using a cloned Conda environment and refresh your packages.
SanchezNuñez
Hi @RobertKrisher
See attached screenshot using cloned Conda.
SanchezNuñez
Found it!!
I just refreshed the exiting tolls and now the “untools” shows on the “Add Packages” list
RobertKrisher
