UNtools for 2.9
4883
6
11-30-2021 10:54 AM
TedCronin
Will there be a UNtools for Pro 2.9?  I see 2.8.2 from inside of Pro and Add Packages.  What is the process to get the 2.9 from Conda\Esri repository?  (Untools :: Anaconda.org)
Tags (1)
MikeMillerGIS
Esri Frequent Contributor
They were shared on anaconda 18 days ago.  If they are not visible in the python backstage, try installing them through the python command prompt.
Click Start - Python Command Prompt
Type the following "conda install -c esri untools"
This should install the 2.9.0 version.
TedCronin
After a refresh the 2.8.2 disappears as well.
MikeMillerGIS
xyz_AL
Correct!
Thanks @MikeMillerGIS
AdamT_GDi
Just installed a fresh version of 2.9.6 to test in the older version of Pro and was only having untools 2.8.0 or older as an option.
Running the above command listed what packages needed to be updated/downgraded/installed. Worked like a charm thanks.
RobertThomson
DanPatterson
MVP Esteemed Contributor
or to have a look-see at what else will happen during an install, here is the conda route... --dry-run is always a good idea at first, remove it if you are satisfied
... sort of retired...
