UN Migration Toolset not honoring Asset Type field input
1481
10
12-10-2025 09:53 AM
NathanGEOregon
Working on our Water UN Prototype, and have successfully delineated all of our primary pressure zones. That felt like a big milestone! I’ve now gone back to the drawing board (re-running Migrate to Utility Network) to try to assign Asset Types to our Water Valves so that I can set Pressure Reducing Valves as subnetwork controllers for delineating our closed PRV subnetworks.
The tool seems to run fine using our “Valve Function” field as the Asset Type input. But after the tool completes, all water valves still have “Water_Valve” as the Asset Group and Asset Type. It’s not splicing or dicing the Asset Type based on the Valve Function field as I expected.
Edit: I do see that it is possible to add Asset Types without needing to "start over" but I kind of want to see how the process goes rebuilding the UN from scratch with the cleanup that I completed thus far.
Any thoughts or recommendations are appreciated!
NathanGEOregon
It worked after I mapped the string data over to a new Integer field and created an Integer coded domain and re-ran the Migrate to Utility Network tool.
(I did download the Utility Network Tools 3.3.3 as Mike recommended, but still had the same issue when using the string field and coded domain)
MikeMillerGIS
Esri Frequent Contributor
Does you source data have Asset Group and Asset Type?  If so, this tools only supports one type field and is not designed to support a UN like source.
If you have a UN like source(AG/AT), I suggest you run the Subtype To Classes tool, which will convert all your Asset Groups to FeatureClasses, then run that input into the tool and select your Asset Type as your type field.
https://esri.github.io/Utility-Data-Management-Support-Tools/docs/3.5/SubtypesToClasses.html
NathanGEOregon
Just using a standard feature class with a domain field. The field type is String, could that be the issue?
MikeMillerGIS
What version of the tool/pro are you using.  We relaxed the ability to use a string as the type field in a later release.
NathanGEOregon
Pro 3.3 with the migration toolset that was provided at the ORURISA UN workshop in Portland with Robert.
MikeMillerGIS
If you look at the properties of the toolbox, it will tell you the version.  I would suggest getting 3.3.3 from here:
https://community.esri.com/t5/arcgis-utility-network-blog/get-started-with-the-migration-toolset/ba-...
NathanGEOregon
Utility Network Migration 3.3.1
RobertKrisher
@NathanGEOregon can you include a copy of the log from when you ran the tool? specifically I'm wondering if there are any warning messages for that field.
NathanGEOregon
@RobertKrisher I did get this error:
 Coded value domain is not assigned or has no values for VALVEFUNCTION on Water_Valve
However the input data did have a coded value domain set for the field, it was just a string field with coded values versus an integer field.
MikeMillerGIS
Did the source class have subtypes? If you want to share the schema, I can take a look at what is going.
