Stormwater Utility Network Foundation v1.4 Questions
1752
04-17-2025 02:02 PM
JayHodny
Hello!  We are in the initial stages of setting up and migrating our stormwater utility to the Utility Network.  We are also doing the same with sanitary sewer.  Can we use the GP tools available in Sewer V2.2 in the Stormwater V1.4 solution?  I am using ArcGIS Pro 3.4.3.  If one had to pick the online 'how to' resources to set up and migrate to the UN for stormwater, what should I choose?  Some of the resources are now 4+ years old.
Thanks, Jay
MikeMillerGIS
Esri Frequent Contributor
All the tools and steps in the new Sewer can be used for Stormwater.  The Editor Map in Storm is very close the the Asset Type map in Sewer.  We are working on an update to Sewer to include a combined model and an update to Storm so it aligns with the other foundation solutions.
MikeMillerGIS
JayHodny
Mike,
Thank you, this is good information.  I forgot to ask, in the Stormwater Foundation do we complete the prototype single user task or skip to the Enterprise task as we have an ArcGIS Enterprise 11.3 test setup?  Our thinking is we go ahead with the single use for data check and cleanup, then make the jump to the Enterprise setup.  Again thank you for the information.
Sincerely, Jay
MikeMillerGIS
Do as much as you can in a single user environment. Only go to enterprise when ready to test multiple user scenarios.
Also, for a pilot, try the new migration tools. They can help you identify errors and play around with the utility network.
https://community.esri.com/t5/arcgis-utility-network-documents/helpful-utility-network-links/ta-p/11...
JayHodny
Good morning Mike,
Thank you again for the information.  We are going to "reboot" our Stormwater UN configuration and follow the sanitary sewer configuration workflow.  Thank you for the blog link, which I have accessed before.  The blog contains a lot of great information and is a top-notch resource, but it can be a challenge to identify direct, relevant topics to watch, work through, etc.  Have a great day.
Sincerely, Jay
