Stormwater Utility Network Elevations not saving
84
yesterday
MarkWasdahl1
We have just migrated an ArcHydro Stormwater File GeoDB to a File GeoDB Stormwater Utility Network v1.4. We have been unable to save Upstream and Downstream elevations for Stormwater Lines. DB is Z enabled with an NAVD 1988 in US-Survey Ft units. XY is NAD83 SP West in US-Survey Ft units. Options: Distance Units are also set to Foot_US. ArcGIS Pro version is 3.5.4. Elevation Z-values are saving to Stormwater Devices.
RobertKrisher
Can you post a screenshot of what attributes or values you are expecting to be updated on the lines class? Do you have any attribute rules written to maintain these attributes as you are creating or updating features?
MarkWasdahl1
The attribute rules remain unchanged from the porting over of the Napierville schema. Values show as zero although I have tried a variety of numbers ranging from single digit to four digits. I simply assumed Stormwater Utility Network v1.4 had this baseline covered. I have attached a sample selected line with attributes shown in three images. All lines and points in this extent passed validation.
